Old 02 Jan 2004, 11:53 am
macster macster is offline
Send a message via AIM to macster
quote:Originally posted by IRPT
Definitely! If you lower it you should get an alignment, at least have it checked. A small drop may not require re-aligning but how can you tell just by looking at it. Better to be on the safe side and at very least have the alignment checked, other wise you may be buying tires a lot sooner than you though.
After I replaced my struts/shocks and springs I had the front and rear aligned. Did not need a camber kit, came into alignment without one.
Ditto
But I needed the front to be adjusted, I had too much toe out.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
