I origanilly went with Progress Spring no alignment kit needed.. Later switched to Goldline Slammer Springs alignment shop was able to get car aligned without a problem.. Slotting the upper bolt hole on the strut bracket will allow you to get the few additional degrees needed.. remember that you want some neg. camber.. Last but not least I went with Air Ride Suspension so my camber will vary depending on the ride heigth that I am running. If an alignment kit is needed then any reputable alignment shop should be able get you aligned without any problems..
Kevin
