  #26 (permalink)
Old 02 Jan 2004, 06:34 pm
Cal Cruzer Cal Cruzer is offline
The engine has wide parameters programmed into the computer to compensate for additonal air flow. Remember that the computer is reading all of it's sensors to try to achieve a perfect AF ratio, mainly for smog purposes, but an incidental side benefit is that and efficient engine is also producing good power. Sticking anything int he path of the airflow will restrict it, even though it is just a silecer. take a straw and suck though it. Then stick a pipe cleaner in it and suck again. You will feel the difference. Then replace the straw with a larger straw. You will get more air. Pretty basic there. It would be an interesting exercise to acutally measure CFM demanded by the turbo at different RMP's and see how much the various solutions acutally deliver. Then you get into porting intake manifolds and heads but as a general rule the things manufaturers do to just the air delivery systems to keep them quite will restrict flow and rob horsepower. Those silencers are obstructions in the smooth delivery of air.
