Thread: engine mounts
Old 14 Nov 2016, 04:34 pm
Fk5 Fk5 is offline
Default Re: engine mounts
Originally Posted by donn View Post
I got the Energy Suspension replacement bushings that are poly urethane. Never will have to do it again.
Motor Mount Inserts - Chrysler PT Cruiser - 5.1105
Took a dremel and cleared out all the old rubber, keep the metal insert and then get 2 of the largest washer you can find.
bolt, washer through insert, then washer and bolt back in place.
Aren't those just supposed to fit through the holes in the rubber on the standard mount to stiffen them up?
2003 GT 5 speed
162,000 miles
