Thread: DYNO RUN
  #22 (permalink)
Old 03 Jan 2004, 06:14 pm
macster macster is offline
Send a message via AIM to macster
[/quote]
Yeah, be careful of that MAP sensor, or chanigng your plugs will get about 40 bucks more expensive. My advice is to remove it when changing the plugs....I broke mine the first time I did a plug change. It comes out pretty easy with 2 torx bolts, and then you just put it back in when you're done.
[/quote]
You ain't really crazy, that's good info. That thing has break me all over it. I got a set of torx tips from Sears when I was picking up the Old Folks tools box, the tips cost me $8.00. And the first thing that I used them for was to remove the MAP sensor so that I could get to the plugs.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
