Old 28 Nov 2016, 10:59 am
ptcruisersteve ptcruisersteve is offline
Default Re: Battery light comes on periodically?
I would suggest making sure when they do the battery load test that your daughter makes sure they input the correct amps in the tester that the battery is suppose to hold. Sometimes they just use the default of 400 amps for a 4 cylinder engine which is inaccurate and gives the wrong results.
You might also want O'Reillys have the OBDII diagnostic connector scanned for any engine trouble codes. If there are any codes write them down and post it here. Clear the engine trouble codes. Sometime replacing a battery may result in pending DTCs? ..
