Old 30 Nov 2016, 02:46 pm
_PTGT03's Avatar
_PTGT03 _PTGT03 is offline
Cool Rockauto Closeout Sale. $1.38 oil/filt. $6.51 brk/pd. $2.97 air/filt $0.50 sprkplg
Wholesale Closeout Parts : 2003 CHRYSLER PT CRUISER 2.4L L4 Turbocharged
$1.39 wiper blades.
Finally all the poor bastards complaining about buying parts for these cars and not being able to afford them can finally rejoice that they aren't driving a mercedes benz that is out of warranty. Lots more listed than just from below.
Belt Drive
Belt
SAVE 47%
(Regular Price: $4.91)
BANDO MFG. 4PK875 {Click Info Button for Alternate/OEM Part Numbers} Info
Alternator [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty]
$2.62
Add Part
Brake/Wheel Hub
Brake Pad
Filter By Keyword(s)
Economy
SAVE 47%
(Regular Price: $12.32)
MONROE FX658 {Click Info Button for Alternate/OEM Part Numbers} Brakes ProSolution Semi-Metallic Brake Pads Includes Hardware Kit Info
Rear [Wholesaler Closeout -- 30 Day Warranty]
$6.51
Add Part
Daily Driver
SAVE 37%
(Regular Price: $18.76)
WAGNER MX759 {#MX641} ThermoQuiet Info
Rear; Except Performance Brakes; OE Semi-Metallic [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$11.87
Add Part
SAVE 41%
(Regular Price: $23.79)
BENDIX MKD841 {Click Info Button for Alternate/OEM Part Numbers} TitaniuMetallic II Info
Front; Abutment Kit Included [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining)
$14.11
Add Part
SAVE 41%
(Regular Price: $25.79)
BENDIX D658 {Click Info Button for Alternate/OEM Part Numbers} Ceramic Quiet Info
Rear; Abutment Kit Included [Wholesaler Closeout -- 30 Day Warranty] (Only 5 Remaining)
$15.30
Add Part
SAVE 37%
(Regular Price: $30.79)
WAGNER MX841 ThermoQuiet; Includes Hardware Installation Kit Info
Front; OE Semi-Metallic; Except Performance Vehicles [Wholesaler Closeout -- 30 Day Warranty]
$19.43
Add Part
SAVE 34%
(Regular Price: $29.79)
RAYBESTOS PGD782M {#PGD658R} Professional Grade; Metallic Info
Rear; OE Pad Material is Semi-Metallic [Wholesaler Closeout -- 30 Day Warranty]
$19.61
Add Part
SAVE 34%
(Regular Price: $43.79)
RAYBESTOS PGD841M Professional Grade; Metallic Info
Front; OE Pad Material is Semi-Metallic [Wholesaler Closeout -- 30 Day Warranty] (Only 8 Remaining)
$28.99
Add Part
Caliper Guide Pin Boot Kit
AUTOSPECIALTY/KELSEY-HAYES HK3077 Info
Rear; w/ 4 Wheel Disc Brakes
Choose:
$1.86
Add Part
Disc Brake Hardware Kit
BENDIX H5721 {#BH5721} Disc Brake Hardware; Pin Boot Kit Info
Rear [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 3 Remaining)
$2.11
Add Part
Drum Brake Hardware Kit
BENDIX H7264 {#BH7264} DRUM BRAKE HARDWARE; DRUM HARDWARE KIT Info
$2.05
Add Part
SAVE 65%
(Regular Price: $5.94)
RAYBESTOS H7168 {#507168, H71682} Professional Grade; Axle Kit Info
Rear
Choose:
$2.05
Add Part
Master Cylinder
SAVE 46%
(Regular Price: $56.79)
CARDONE SELECT 132923 {#5015160AA} w/ Reservoir Info
Previous Image
Next Image
$30.79
Add Part
Parking Brake Lever Spring
BENDIX H702 Info
R Return Spring Set w/FT DISC/RR DRUM
Choose:
$5.01
Add Part
Rotor
RAYBESTOS 780135PL Advanced Technology; Performance; Drilled & Slotted Outside Diameter 10.63" Info
Rear Left [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
Previous Image
Next Image
$23.09
Add Part
Cooling System
Radiator Lower Hose
SAVE 41%
(Regular Price: $11.74)
DAYCO 72074 Curved Info
$6.90
Add Part
Radiator Upper Hose
CONTINENTAL 1295 Info
CURVED BASE MODEL LIMITED TOURING [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining)
$5.66
Add Part
Thermostat / Thermostat Housing / Water Outlet Seal
SAVE 53%
(Regular Price: $2.77)
FEL-PRO 35681 {#4792637AA} Info
Thermostat Housing Gasket [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$1.29
Add Part
SAVE 53%
(Regular Price: $3.15)
MAHLE ORIGINAL/VICTOR REINZ C31736 {#4792637AA} Molded Rubber Info
Water Outlet Gasket [Wholesaler Closeout -- 30 Day Warranty]
$1.48
Add Part
SAVE 53%
(Regular Price: $3.35)
MAHLE ORIGINAL/VICTOR REINZ C31646 {#5278144AA} Molded Rubber Info
Thermostat Gasket [Wholesaler Closeout -- 30 Day Warranty]
$1.57
Add Part
Water Pump Gasket
SAVE 53%
(Regular Price: $2.44)
MAHLE ORIGINAL/VICTOR REINZ K31502 {#4621564} Molded Rubber Info
Housing to block [Wholesaler Closeout -- 30 Day Warranty] (Only 12 Remaining)
$1.14
Add Part
Electrical
Starter Motor
ULTIMA 399760
New; BASE MODEL - LIMITED - TOURING [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
Previous Image
Next Image
$55.79
Add Part
Emission
EGR Gasket
SAVE 52%
(Regular Price: $2.22)
MAHLE ORIGINAL/VICTOR REINZ G31321 {#4663247, 4663247AB} Beaded Steel Info
VALVE
Choose:
$1.07
Add Part
Knock (Detonation) Sensor
SAVE 12%
(Regular Price: $11.67)
AIRTEX/WELLS 5S2346 {Click Info Button for Alternate/OEM Part Numbers} Info
Previous Image
Next Image
$10.25
Add Part
Engine
Camshaft Seal
SAVE 54%
(Regular Price: $3.58)
FEL-PRO TCS45961 {#46486078, 4648608, 4777086} Camshaft Front Seal Info
Front [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining)
$1.65
Add Part
CORTECO 14545 Info
CAM OIL OR TIMING CVR SEAL B, G Engine CODE [Wholesaler Closeout -- 30 Day Warranty] (Only 5 Remaining)
$3.56
Add Part
Circular / Semi-Circular Plug
SAVE 54%
(Regular Price: $1.86)
FEL-PRO ES72357 {#4884880AA} Info
Valve Cover [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$0.86
Add Part
Conversion (Lower) Gasket Set
SAVE 38%
(Regular Price: $91.79)
MAHLE ORIGINAL/VICTOR REINZ CS54044C {#4777994AE} Material: Rubber Info
Use with Head Set to Make Full Set [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining)
$56.79
Add Part
Crankshaft Seal
SAVE 52%
(Regular Price: $5.54)
MAHLE ORIGINAL/VICTOR REINZ JV1654 {Click Info Button for Alternate/OEM Part Numbers} Fluoroelastomer Info
Rear
Choose:
$2.66
Add Part
SAVE 54%
(Regular Price: $6.44)
FEL-PRO BS40182 {#4621939, 4667322, 4667904} Rear Main Seal Set Info
Rear; Rubber; One-piece; Rear Main Seal Set [Wholesaler Closeout -- 30 Day Warranty]
$2.96
Add Part
SAVE 54%
(Regular Price: $7.93)
FEL-PRO TCS45962 Crankshaft Front Seal Set Info
Front; Crankshaft Front Seal Set [Wholesaler Closeout -- 30 Day Warranty]
$3.65
Add Part
SAVE 54%
(Regular Price: $10.97)
FEL-PRO BS40627 Rear Main Seal Set Info
Rear; PTFE Rubber; One-piece; Rear Main Seal Set [Wholesaler Closeout -- 30 Day Warranty]
$5.04
Add Part
Cylinder Head Bolt
SAVE 52%
(Regular Price: $21.79)
MAHLE ORIGINAL/VICTOR REINZ GS33343 {#6504033} Info
$10.40
Add Part
Cylinder Head Gasket / Head Gasket Set
SAVE 51%
(Regular Price: $84.89)
MAHLE ORIGINAL/VICTOR REINZ HS54420C Set Info
[Wholesaler Closeout -- 30 Day Warranty] (Only 7 Remaining)
$41.79
Add Part
Intake Manifold Gasket
SAVE 53%
(Regular Price: $5.22)
MAHLE ORIGINAL/VICTOR REINZ MS19479 {#4884195AA} Paper Info
Includes Plenum Gasket [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$2.43
Add Part
SAVE 42%
(Regular Price: $4.69)
FEL-PRO MS96198 {#4884195AA} Set Info
Upper set incl. [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$2.72
Add Part
Oil Filter
CHAMPION FILTER CL3600
GT [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$1.12
Add Part
HASTINGS FILTERS LF134F Info
GT [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty]
$1.17
Add Part
CHAMPION LABS PH400 Info
$1.38
Add Part
FVP R1516
SPIN-ON - GT [Wholesaler Closeout -- 30 Day Warranty]
Previous Image
Next Image
$1.38
Add Part
PERFORMAX PO19
GT - HI OUTPUT [Wholesaler Closeout -- 30 Day Warranty]
$1.38
Add Part
PERFORMAX PO21
L4-2429CC/148CID 2.4L Engine - B Engine CODE [Wholesaler Closeout -- 30 Day Warranty]
$1.38
Add Part
PREMIUM GUARD PG195 Premium Guard Standard
Previous Image
Next Image
$1.38
Add Part
PRIME GUARD POF241 Info
$1.38
Add Part
PRO-TEC 116 ProTec Spin-On Lube Filter Info
$1.38
Add Part
PROMOTIVE FILTERS PH195
GT - HIGH OUTPUT [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$1.38
Add Part
PUROLATOR MGL51516
GT - CANADA equipped - US equipped - MANUFACTURER OE RECOMMENDED OIL CHANGE INTERVALS [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
