Old 02 Jan 2017, 03:45 pm
rob302's Avatar
rob302 rob302 is offline
Default Re: What to do with my beloved PT?
he was likely wrong about the compressor being the leak. the lines chafe and wear through on these cars. you can follow the 2 fat lines up with your hand and see for yourself what i'm referring to. you can't see it unless you pull the two lines apart and look.
post about when i fixed mine:
broken AC line, $0
6" gas pipe with threaded ends, $2.99
2 hoseclamps, $3
result:
i know it isn't the right way, but it was 100 out and i had a lot of driving to do. i fixed it in the parking lot, charged it, and
it worked great. this will never wear through and it still holds pressure and still works properly a full year later.
what doesn't work with the heat? the air coming out of the vents? the temperature?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
