Old 30 Jan 2017, 02:51 pm
Handy_Cruiser's Avatar
Handy_Cruiser Handy_Cruiser is offline
Default Re: Srt gauge cluster in PT cruiser
Cool idea. I assume your are talking about an SRT4 Neon cluster and not the cluster from an SRT Charger, Challenger or 300.
But sadly, no. Not only is it a completely different fit, but the cluster in the PT also contains the Body Control Module (BCM). While likely similar to the PT, the Neon BCM is probably going to cause a lot of 2nd-order compatibility problem. If installing a PT GT cluster in an NA PT causes issues (I once attempted that), the SRT4 Neon cluster will most certainly do the same.
