Old 30 Jan 2017, 02:53 pm
rob302's Avatar
rob302 rob302 is offline
Default Re: Srt gauge cluster in PT cruiser
it would not even almost fit. the connector is in a different location. the connector on the PT is molded into the dash plastic.
nothing with that cluster would fit. even if the instrument panel did, the bezel around it would have 3 big holes instead of the neons 2
___________
it seems like you secretly want an srt4 neon. you might consider swapping a whole neon dash into the PT, painting it black, and then adding the SRT cluster
