Headlights and door locks stopped working?
Ok i came home last night and headlights were fine as were door locks came out to car today keyless entry doesnt work so i open with a key and decide to start it up to see if it is ok . I start it and no problems. I try my headlights to see if all is ok, they do not come on and neither do the fog lights or driving lights. I took it to the dealership they hooked up the scanner per repair manual instructions nothing showed up they said the batter being disconnected flashed all codes. I had the battery disconnected to clean the terminals after the keyless wouldnt work thinking it was bad connection.
I tested resistance on the drivers door lock switch. I can hear something actuation from the relay in the center of the dash when locks are pushed and when keyless is used.
I have an appointment for a week today, what could it be anyone have any idea or had a similar problem.
all is under waranty still so i hope it can be fixed.
Dan
