quote:Originally posted by FRM3
Just got my 2 15" Kosei K-1 wheels (13.5 lbs each) clad in BFG Drag radials 205/50/15.
Got the idea from the SRT forums where lots of folks are running them with great results.
They fit calipers fine and drop the front end 1 to 1 1/2". Plan on pushing them hard at the strip this weekend. In the meantime made a trial run and they really do grab! Looks like I should be able to leave with NOS on in 1st Gear. I also assume that due to the size difference my final drive ration will go up giving me more pull down low.
I hope the automatic will not shift to od before end of 1/4, but even if so the hook up and mid range should really help.
Lack of traction has been my biggest et problem. I will let you know the difference.
Hey are you still running that 35 shot of Nox? Can you post pictures of the wheels?
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
