Dbrown..
I know that I'm jumping in on your forum, but anything o do w/airride suspension I just can't resist.. Install isn't as difficult as people may think.. Did my own install 1 yr ago and no problems.. just take your time, route your air line away from any moving parts or heat sources, and make clean cuts to avoid leakage.. As far as the the suspensions cpmponents(Bags, stuts, and valves.. thats the easy part.. If you can install tsruts then you can install the airride suspension parts.. Give yourself a good weekend to do right the first time.. Much more pride when done knowing that you did it yourself than paying someone $$$ to do it for you.. PLus all the questions you'll be askd baout the system you'll be able to inform people in detail about the system.. to bad you didn't live in Oregon hell I'd help you it for lunch and some beers
Kevin
