  #20 (permalink)
Old 06 Jan 2004, 11:21 pm
Mean Green Mean Green is offline
quote:Originally posted by Mel K
Went to Home Depot and picked up at 3" special PVC "L" for under $8. Had to shorten it at both ends but works pretty well fitting between air box and wheel well intake. I had removed the complete intake housing, leaving a 4" x 5" hole in the air box. A rubber collar, again from Home Depot makes the fit to the airbox cleaner. The "L" is slightly larger than the wheel well opening, but I think that this is better than runnig a smaller diameter tubing down to the front end.
I just took a hack saw and cut that silencer so that it is flush with the inside of the box. That way the outside scoop part is still sticking outside of the box and covers the hole in the fenderwell. Works great with the 2" hose I have going down to the front of the car. My turbo up pipe is always icy cold. Congrats on coming up with something else to make your air box work better. [?]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
