  #13 (permalink)
Old 07 Jan 2004, 03:50 pm
kevinl1058 kevinl1058 is offline
Actually,
The hardest part I had was mounting the tank, starting the nut and lock washer while trying to keep the bolt from spinning was time consuming.. You know those tight spaces.. That was it.. Running the air lines putting grommits in all holes drilled out to run the lines through was just time cunsuming because I wanted a clean path.. Remember the episode of monster garage when there air ride suspension let out because they mounted the air line over the exhaust pipe.. Other than that its an easy install..
