Old 22 Apr 2017, 07:42 pm
ptprice's Avatar
ptprice ptprice is offline
Default Re: Should I buy? 2007 52K miles
If your replacing the front bumper cover that could be a couple of hundred. If they could have fixed the A/C cheap it'd a been fixed already! Figure at least $600 to $1000 for a new air conditioner compressor and other necessary A/C work and fixings. The mileage is OK but it's still ten years old. Next'll be the timing belt. Probably won't be mileage but the ten years! The A/C might be why they're dumping it!
I helped a friend looking for a PT Vert a few weeks ago with similar mileage. The dealership brought it to "good ?" condition. Every thing finally worked. It was loaded! My friend passed up buying it even though the deal ended up being around five "G's" out the door at the dealership! I found hidden body damage repair they'd hoped wouldn't be noticed!
HOW TO CHECK FOR A CLUNKER!To check for Bondo take a simple five dollar telescoping magnet, gently pinch the first extension so the magnet, padded with masking tape, (DON'T SCRATCH THE PAINT!) will still hold on a good metal surface and the pinch allows the telescoping function without the magnet coming loose. It should hold all the way out to full extension! Put one or two business cards between the magnet and the good metal surface and pull the telescoping feature out of the pinched portion once again. The card, representing just a bit of Bondo will space the magnet far enough from the surface so it won't hold efficiently. BONDO! BEWARE! You'll have a $5.00 Bondo tester as good as a high dollar paint thickness tester.
Don't be fooled with those shiny tires. Check to see if they're a set, the proper size, how they're worn (wear pattern) and how much they're worn!
Also check for over spray and bad tape marks indicating a repaint or touch up! Check for pulling, wandering, vibrations, brakes, idle exhaust flutter, oil fill hole flutter test and alignment. Peek at all dip sticks, reservoirs, belts, wires and hoses. Try every light, signal and accessory a few times. Put a volt tester on the battery without the PT running. Hope for at least 12.5 to 13V. Start it up and expect for more! Crawl underneath or better yet get it on a rack. At least look for leaks.That you can do.
Finally, always have an independent garage check it out. $30 bucks or so there can save a lot of head aches! NO surprises! this kind of act can really PO a dealership and even private sellers. Once in a while you'll find an honest one but let the buyer beware! That's you!
I'm sure I've missed lot's you should look out for. You've come to the right place to find it as far as PT's go! I'm just an old and forgetful geezer who enjoys his PT!
I'd suggest using the info you get on the Forum and try for a much better price or move on. rckstein's advise very valid.
Happy Ptin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Custom Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. Aluminum Chrome Clad 16" X 6" Wheels, P250/55 R16 Cooper Touring tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
