Old 08 Jan 2004, 08:46 am
IRPT IRPT is offline
Lt Almond GT, sorry. Here you go, this is from the 2003 service manual:
REMOVAL - 2.4L TURBO
Special care should be used when installing spark
plugs in the 2.4L cylinder head spark plug wells. Be
sure the plugs do not drop into the wells, damage to
the electrodes can occur.
NOTE: REMOVE cables from the coil first before
removing spark plug insulator.
(1) Disconnect the negative battery cable.
(2) Unlock and disconnect the MAP sensor electrical
connector.
(3) Remove the throttle control shield.
(4) Disconnect the cable from the ignition coil first.
Always remove the spark plug insulator, rotate the
boot 90° and pulling straight up in a steady motion.
(5) Remove the spark plug using a quality socket
with a rubber or foam insert (Fig. 30).
(6) Inspect the spark plug condition.
2002 Inferno Red PT Limited
Mercedes Wiki
