Old 03 May 2017, 05:47 pm
JohnPTCruiser JohnPTCruiser is offline
Default Light Knocking Noise after engine rebuild
This is a fresh rebuild for a 2004 PT Cruiser 2.4L(Non-Turbo). Engine rebuild included brand new connecting rod with new pistons, rod bearings, new crankshaft, main bearings, balancing shaft chain w/ tensioners, oil pump, timing belt w/tensioner, and cylinder head has new valves & new lifters. I'm getting a light knocking noise @ 2000rpms holding steady on throttle. Anybody ran into this issue before? Any suggestions or things to check to pin-point the knocking noise? Appreciate your help in advanced!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
