Does your wheel shake when you apply the brakes? If so you probably have warped rotors. This can also cause the shakes at certain speeds if the warp is bad enough as the rotor rotates and comed in contact with the brake pads. Otherwise you may have thrown a wheel weight. HAve the balance checked out.
