Old 13 May 2017, 04:41 pm
JohnPTCruiser JohnPTCruiser is offline
Default Re: Light Knocking Noise after engine rebuild
I took off the oil pan. I checked the balancing shaft chain. The chain is loose on the left side where the guide is not adjustable. The right side with the adjustable guide, the chain was not loose. Does anyone know if there's a difference between OEM chain and Aftermarket chain? I have the aftermarket chain which does not have the 2 color marks like OEM chain.
The crankshaft is reman. or considered new. New main bearing and rod bearings are also new. Pistons and connecting rods are new as well.
Side note: The knock doesn't happen when the motor is cold, only noticeable when the motor is warm. Could I be possibly chasing the wrong thing??
