Old 18 May 2017, 02:14 am
AngryPTOwner AngryPTOwner is offline
Default Re: 2006 PT Overheating issues
Originally Posted by rsrocket1 View Post
Never mind.
I wanted to welcome you and encourage you to introduce yourself since you don't show anything on your profile. Then I looked up your previous posts.
Looks like every time you start a thread you are about to give up on this car
Did you ever get your camshaft sensor problem fixed from 2011?
You never replied whether or not the help given here fixed it I lost those threads LONG ago. Camshaft sensor has been replaced yearly since 2011 WITH the crankshaft sensor. Mopar , dealer parts, or something from Autozone they keep failing
Did you ever get your grinding noise problem fixed from 2012?
You never replied whether or not the help given here fixed it Grinding noise was the idiots at Midas messing up a caliper when they rotated my tire. The replaced everything
Did you ever get you headlight problem fixed from 2013?
You never replied whether or not the help given here fixed it. Nothing fixed the headlights. They are still non functional. Dealer tired a new TIPM, flashed it , they didn't turn on. They said "It'll probably be another $1200 to take the dash apart and find whatever electrical problem is causing all this." I declined and I just drive around with brights on.
Did you ever get your crankshaft sensor problem fixed from 2015?
You never replied whether or not the help given here fixed it Crankshaft had to be replaced yearly along with Camshaft.
This car has quite literally been the worst car I've ever owned. It's always in need of something repaired every 3-5 months like clockwork.. I got it in 2007, one week after I got it, my drivers side window fell in the door. The dealer said it was "Defective" and replaced the door.
2008 Less than a year of having it, front drivers side tie rod broke.
2009 First camshaft / crankshaft sensor replaced
2009 Back windshield wiper won't turn on
2010 Front windshield wipers won't turn off
2010 two lugnuts just "fell off"
2010 First battery dies
2011-2017 some of the problems listed above not to mention replaced every sensor on the car, AC problems, Back windshield wiper is dead again, exhaust had to be replaced completely and i can't open the passenger side door from the inside.
This car is extremely unreliable. I'm not one of those people who doesn't get it serviced ether. I always get it routinely looked at.
