Old 18 May 2017, 02:18 am
AngryPTOwner AngryPTOwner is offline
Default Re: 2006 PT Overheating issues
Originally Posted by JDK52 View Post
With all the work you have done to make this right, it is easy to see why you are angry!
In your list of replaced parts I did not see a thermostat.
Even if the thermostat was replaced, sometimes new are defective.
If all else has been tried, I might perform one of those chemical tests on the coolant to detect a failed head gasket.
Good luck.
We did replace the Thermostat. I guess I'll have to check that to see what's up. Didn't think about trying a chemical test. It randomly overheated again today this time at 60 mph going up an on ramp. When I finally got it cooled down enough to drive it home at night it did not over heat, however it still making a "gurgling / bubbling" sound when i turn it off. There is no spillage or leaking overflow. Coolant did not spill out... I'm literally out of ideas of what it could be. The only think I can think of is maybe the Temp Sensor is faulty? Or the TIPM is making the Temp Sensor faulty? It couldn't be a Temp Relay could it?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
