Well I worked for HESS gas back in the day. I can tell you ALL tanks have water in them! I stuck enough tanks over my time there to know, we had a paste we would put on the stick to see how much water was in the gas. We had a limit of inches per tank and then we had to have it pumped off. Also never get gas while or right after a tanker drops a tank, it mixes the underground gets the water moving up the lines, and stirs all the silt on the bottom of the underground.
Also I think 93 octane is 93 octane in this day and age. There are only so many places refineing oil to gas. I do use Hess 93. I use Sunoco 94 in my bike. There is only one Sunoco in my area that has a hose for each grade, on a bike gettin only 3 gal gas, I dont want the hose, pipe, pump, full of the last customers grade.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
