P2074 CHRYSLER Manifold Pressure
2006 pt cruiser base, we did the head and timing belt last year
Now is having a problem and I can find the solution, I need help!!
car sounds horrible and idles bad 500 to 1500 rpm's jumping up and down all the time if I drive it runs ok but don't have too much power
a new manifold pressure sensor, pvc valve, vacuum connector from the brake booster was installed still the same problem
I replaced the intake and throttle body from the junkyard, still same problem
I can't find the leak, what else can I check?
thank you
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
