Re: P2074 CHRYSLER Manifold Pressure
I would suggest using a vacuum gauge for reading, if the belt is off a tooth it will reflect in either a very high idle HG or very low. An engine that is in good condition will idle between 16-18 steady on most 2.4 engines. Post what you find.
