quote:Originally posted by dfunkdj
How hard was it to install the Apexi boost controler
Don
This is how The solenoid was installed:
The hose on the left goes to the wastegate. The one at the bottom of the solenoid connects to the turbo exhaust fitting.
The wiring goes thru the firewall using the parking brake hole and into the glove comparment.
In order for you to use all the fetures of it, you have to tap into the PCM wiring. TPS, RPM, Vehicle speed and tap to a VAC hose for its own Boost sensor which is behind the APEXi Solenoid with the blue line.
