Quicksilver gave you great advice. Other things to watch out for: Have a good torque wrench available and follow the instructins when tighening things down. The two bolts on the rear ECM pipe are different sizes (8mm & 10mm if I remember right) and their a real pain to get to..take your time! Last but not least, hold on to everything really good when taking the small nuts and bolts off...if you drop it, 99 out of 100 times it won't fall right thru and hit the ground making it easy to find! (that's from experience
