  #14 (permalink)
Old 07 Aug 2017, 09:08 pm
ptcruisersteve ptcruisersteve is offline
Default Re: No Power From Alternator After Trans Swap
Check to see what the battery voltage is at 2000 rpm. Make sure battery is fully charged and is at or above 12.5 volts with the ignition off.
