I installed the ZEX Wet nitrous in my neigbor's car and it is a great kit! All you need for the instalation is included exept the Wrenches and the Dril bit for the mounting clamp. it comes with all the nessesary wire taps and plugs for a clean install. It even has a tool to remove the valve at the shrader conection. No microswitches to deal with. Just tap the TPS and perform the 10 sec learning mode and you are done. The hardest part is drilling the trunk for the four bolts that will hold the bottle in place and in his case a hole to exit the Nitrous line and one for the blow out tube.
I am thinking of buying for myself the Venom wet system for Returnless fuel systems.
Just remember to buy the safety blowout tube for you to run at the tracks. This item is mandatory for all open rear trunk.
Ian
