Old 25 Sep 2017, 11:23 am
myckee myckee is offline
Default Re: Anti Theft, Security and Immobilizer
Originally Posted by Handy_Cruiser View Post
Welcome to the forum. And this is a great write up. But I have several questions.
First, if the 1/2 hour key programming actually works, that's new information for the PT Cruiser. At least it is to me. And if it did work, did you use an original key in any way during the process?
Next, since you removed the board from the original SKIM and placed it in the salvage module, the salvage module then effectively becomes the original with the same programming. But the required handshake to make the car run (stay running) is between all three, PCM, SKIM and mated sentry key. So did you simply use the lock cylinder and sentry key from a salvage car? If this is the case, it means anyone without a functioning sentry key can simply replace the lock cylinder and sentry key with another pair from a salvage car, turn the ignition on for 30 minutes and then drive the car. Is that the way this really works?
And there's a third ramification of this that would really be useful if I understand what's been said. It also means someone can buy a new sentry key, have it cut to fit the existing lock cylinder, and then program it themselves by leaving it in the ignition in the on position for 30 minutes.
This is good stuff if confirmed.
I don't know about the 30 minute programming, but I can shed some light on the skim board replacement. I have done this myself a few months ago.
What the original poster was saying, is that the original skim on his car had a broken antenna. The antenna is integrated into the Skim housing itself and cannot be removed. So what he did was desolder the board from the housing/antenna of his cars original SKIM. Then he did the same thing with the junkyard skim. He would have discarded the board that came with that skim and soldered in the board from his original skim. Now he has a fully functioning "original" skim for his car and he can continue to use his original key. All three match, skim, key and pcm.
I had to do this exact thing. I had gone to the junkyard to buy a key and skim so that I could program and sell a matched set to a customer. However when I was removing the skim I accidentally broke the antenna. This was the only 03 in the yard with a matching key present. So I had to do the exact board swap the original poster did. I can confirm that if you are careful and gentle and are proficient with de-soldering and soldering, it is quite easy and possible to do and it works.
