Old 10 Oct 2017, 10:54 pm
_PTGT03's Avatar
_PTGT03 _PTGT03 is offline
Default Re: DST CMR Custom tunes
Originally Posted by zztunnell View Post
Is there anyone on here currently that writes tunes for the DST? Or know someplace that does?
I'm having trouble finding a tuner that is still current and actively writing tunes for the 2.4l cars.
Seabiscuit is running rich at WOT and under a moderate load. I played with the WOT fuel parameters at the track Sat. It was running 10:1 on the UEGO at WOT. After goin to 25% lean on the 3-4k, 4-5k, 5-6k and 6-7k. It was still mid to high 10s.
I suggest you contact Kevin Sykes at his tuning performance shop in Washington. he makes a special tuner with available computer software that I'm sure will meet your expectations.
Syked Ecu Tuning | Dodge Tuning Software
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter delete. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
