Thread: Heated Mirrors
Old 06 Nov 2017, 09:23 am
linkinparker445 linkinparker445 is offline
Default Re: Heated Mirrors
I added heated mirrors to my car by using a pigtail connector to replace the connector located behind the door panel. I cut it from the same car in the salvage yard that had the heated mirrors I took. Then you can splice in the new connector and run a new wire through the door for the defroster.
2004 Touring Turbo Lite, Hahn 20g turbo, ATX ->T350 5-speed swap, mtx stage 1 pcm, DiabloSport InTune, rear sway bar, Wilwood big front brakes, rear disc brake conversion, Drop Zone springs, SRT4 dual exhaust
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
