Old 07 Nov 2017, 09:17 am
rsrocket1's Avatar
rsrocket1 rsrocket1 is offline
Default Re: New radiator fan, and now new problems
If you bought the fan assembly with the 4 pin connector, it should have new relays. The part without relays would only have a 3 pin connector. If you look at the clean fan on the right in the picture below, the relay harness is the thick cable going from the 4 pin connnector on the bottom of the housing over to the relays in the upper right corner. The 3 pin connector cable with the blue wires goes from that harness directly to the fan motor. You should be able to tell if the relays were reused or not because the black plastic on the relays and cable would be faded and worn.
The relays are bolted to the upper passenger side of the fan when it is installed in the car.
When you say the high speed relay is sticking, is it on all the time? Did you try the test with turning on the A/C, checking that the fan is running at high speed, then turning the A/C off and seeing the fan go off high speed? (If your engine is already up at operating temperature, the fan could revert to low speed, but you should be able to tell the difference between high and low speed).
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
