Old 07 Nov 2017, 02:14 pm
ptcruisersteve ptcruisersteve is offline
Default Re: OBDII scanner recommendations for average person
I recommend the Professional OBDII Scan Tool #60694. I have the Professional OBDII Scan Tool #60693 which is almost exactly the same.
Graphs data for 1996 and newer vehicles
I/M Readiness Key for quick drive cycle verification and state emissions readiness check
Retrieves generic codes (P0, P2, P3, U0), manufacturer codes (P1, P3, U1) and pending codes
Provides Code/Cause/Solution tips for easier troubleshooting
Displays live 02 sensor data
Retrieves vehicle information (VIN, CIN and CVN)
Views freeze frame data
Trilingual menu and DTC definitions - English, French, Spanish
No batteries required, powered by vehicle's battery. The software update with instructions is available for download under the Software Update tab above.
Some members will recommend a cheap scan tool or reader only because they already know the codes and know the common causes of those codes. They are not thinking of a new member who is getting their first OBDII Scan Tool and these members will get discouraged with the cheap scan tool/reader and get an more realistic OBDII Scan tool that will help them. I was recommended the Professional OBDII Scan Tool #60693 from Harbor Freight and have not had to use any other more expensive OBDII Scan Tool to fix any issues that has come up on my Pt Cruisers. Don't let anyone convince you that the cheaper OBDII Scan Reader with less features will do the common problems that you might have with your Pt Cruisers. Do your homework. I have convinced Shelby5041 to go with an OBDII Scan Tool with the same recommended features or more.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
