Old 09 Nov 2017, 02:26 pm
ptcruisersteve ptcruisersteve is offline
Default Re: new thermostat but still no heat from heater any ideas
Originally Posted by chrissy View Post
hi can anyone help have just put new thermostat in because there was no heat coming from heater but still no heat i have 2.2 crd 2004 i think it might be air lock have tried to bleed from the bleed screw on end of radiator but no water comes out any idea any one please
Have you tried burping the radiator. Just remove the radiator cap with the engine cold, start the engine, let the engine get to normal temperature reading where the thermostat opens up, after a few minutes where you can see the thermostat has open up, turn the engine off and refill to the top. Do not let it run too long as the coolant will start to come out at the top.
If you still have air in the coolant system after burping it I would suggest raising the front of the Pt Cruiser, leave the radiator cap off overnight and in the morning most of the air should be removed from the coolant system.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
