Old 10 Nov 2017, 12:03 pm
Handy_Cruiser's Avatar
Handy_Cruiser Handy_Cruiser is offline
Default Re: new thermostat but still no heat from heater any ideas
If the issue is just no heat from the heater but the gauge needle is reading about right in the middle when the engine is warm:
1. First make sure the air is bled out of the cooling system as Steve recommended.
2. ]If all is good, It may be a problem with the blend door or the controls. [EDITED] Go here for directions on how to check this.
If not working correctly, you will need the service manual for further diagnostics. Here's a copy if you don't have one:
https://drive.google.com/file/d/0B9C...ew?usp=sharing
3. If this is not the problem, you may have a clogged heater core. To service this, you will need to take both heat hoses loose and back flush the heater core assuring good flow.
Of course, the issue could be other problems as well. But I believe these are the most likely based on what you have said.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
