Old 10 Nov 2017, 01:08 pm
sanatanadharma's Avatar
sanatanadharma sanatanadharma is offline
Default Re: new thermostat but still no heat from heater any ideas
Originally Posted by Handy_Cruiser View Post
... The vacuum solenoid for the blend door is behind the glove box. It's usually silver and easy to identify. Just put your hand on it and see if you can feel it working when you change the temp control with the heater on and the engine running. You should feel and possibly hear the movement. ...
Respectfully, the vacuum canister is the actuator for the fresh air/ recirculation control. Vacuum holds the diverter door in recirculation position. When the car is off or the vacuum fails, a spring resets the fresh air/ recirc-door to fresh air position.
The temperature control (air-blend door) works by a direct cable mechanical connection.
All fresh or recirculated air flows first through the A/C evaporator (which cools and dries only when the A/C compressor is operating).
Then the air blend door (temperature control) diverts some or all of the air (that passed through the A/C evaporator) to flow through the heater core as well.
The engine coolant flows through the heater core whenever the motor is running. There is no water flow control.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
