Old 10 Nov 2017, 10:29 pm
siamese_retriever siamese_retriever is offline
Default Re: New radiator fan, and now new problems
Thanks! So, here is where I am at now -
1 - I have now replaced (2) high speed fan relays that should be mounted to the radiator fan (see #5).
1a - I am now really good at changing these relays!
2 - I am 98% sure it is the 4 pin version. I don't know for sure yet, as this was replaced by a Chevy dealer about 65 miles north of Louisville, Kentucky last week. I will try to verify tomorrow. I live right outside Chicago, and they were the only ones open.
3 - I get code P0480 about 2 minutes after I clear the car using a cheap OBD2 scanner.
4 - I got the coolant flushed and replaced a few days after I got to where I was going, so I can safely say the coolant is good.
5 - The dealer did not put the relays back on the fan housing where they were supposed to be. I am NOT happy about that. Not only that, but there is no bracket there. Just the holes where it should be attached. Grrr...
Next up - I am trying to figure out if I change the coolant temp sensor or the wiring harness for the relays. I assume the harness is the next likely suspect, but I suspect I have to get the fan out to replace that harness.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
