Old 10 Nov 2017, 11:45 pm
rckstein's Avatar
rckstein rckstein is online now
Default Re: New radiator fan, and now new problems
Check this connector at the bottom of the fan, on the drivers side, it was melted on mine when my PT had a fan issue. If they reused the old harness, the contacts in this connector may be melted or show signs of arcing and not making a good connection. You can also apply a very small amount of dielectric grease to the connector prongs to help with making a good electrical connection.
How and where did they mount the relays, did they zip tie them somewhere?
This is how the relays should be mounted to the fan:
If they didn't mount them to the fan, that's not a proper installation. Since you had it done at a dealership, you are still under warranty and you should be able to take it to any other dealership to be corrected.
Did you look on your invoice and does it have a part number for the fan they installed, if so, what is it?
The fact that the relays are not mounted to the fan tells me that they got the bare fan from NAPA and reused the old relays and old wiring harness. If they had gotten the complete assembly the relays would already be mounted onto the fan housing.
'06 Touring Edition NA Automatic
153k Miles / Electric Blue Pearl
USMC '82 - '93
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
