Thanks, 3BAR, that helps a lot!
There is no discernible knock or plug problems. What's odd is I do not notice boost pull during the run and pyrometer readins seem reasonable. However, when starting back up return road with Nitrous off I check boost at WOT in 1st Gear and that's when I discover boost being limited. Also, as I understand your response the overly rich state should not be thte culprit.
I assume when you suggest re-jetting the NOS you mean richen the mixture slightly?
Thanks
Frank
03 GT, Stage 1
Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed.
