quote:Originally posted by bobs turbo pt
your fix still working??
Yeah
It should because it is similar to the original configuration. Instead of the factory clamp, it has a hose clamp. All I did was to push the hose forward and install a clamp right behind the old one and tighten it securely. The fitting that the hose is clamped to has a ridge at the aft end pointing toward the back of the car. so baring a cracked hose or fitting installing a hose clamp there should be 4.0.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
