Old 18 Nov 2017, 07:51 pm
rambojoe rambojoe is offline
Default Re: Strange Issue With My PT Cruiser
what store did you buy the sensor at and how long ago? the cheap ones do not last at all... maybe someone can post how to test it if you're handy with a multi meter but chances are its bad. every time we got that code regardless of how old it was, that was the issue. and we bought 2 from autozone till we bought one from the dealer once you get it running then see if the other code still comes up,
some members had to replace the magnet on the actual cam that signals the sensor, fwiw, we have the same year and ours is original- albeit with no visible damage. when its time to change the crankshaft sensor, do yourself a favor and use oem Chrysler- its a bear to change. might as well do it now!
I forgot... so killing the battery and getting the codes were surely just a fluke. weird stuff happens...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
