Old 26 Nov 2017, 07:43 pm
rckstein's Avatar
rckstein rckstein is offline
Default Re: 2007 pt cruiser engine needs to start twice
Originally Posted by TDFF View Post
My 2007 pt cruiser has a weird problem. When the engine is cold (overnight), the engine will crank but won't start in the first try. It will start in the second try. However, when engine is hot, it starts fine. Also, the check engine light is not on. The problem starts this Oct. when temperature starts to be low in the morning (32F). But because the car start eventually, the battery should be OK, right?
The engine cranks and it will start eventually, so the starter should be fine, right?
I tried to turn the key to ON without starting the engine and waited for a few seconds, the engine still could not start in the first try but will start in the second try. So I think the fuel pump and fuel filter should be fine, too.
I did an oil change this Sep. and the car past the NY state annual inspection this Oct.
So what do you think is wrong?
I'd like to take the car to a mechanics for an inspection. However, it seems that it is really hard to repeat the problem right away, and I don't want to leave the car there for a few days. I appreciate it very much, if anyone could point me to a possible cause.
Thank you very much.
Welcome to the forum
Your PT sounds like it has the same problems as mine when the fuel pump was going out. After sitting overnight, it would have a long crank on a cold engine. But after starting and repeatedly shutting down and restarting numerous times throughout the day, it would run fine. Then hard to start again the next morning.
There is no fuel filter and you can have a fuel system pressure test done. Which I did have and the fuel pump was supplying enough pressure and the fuel injectors were not leaking down. Apparently there is a check valve in the fuel pump that was not holding the system pressure overnight but slowly leaking down. Had the fuel pump replaced 08/14 and has fired up within a few seconds ever since.
When you get a chance please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread.
