Originally Posted by rckstein
Welcome to the forum
Your PT sounds like it has the same problems as mine when the fuel pump was going out. After sitting overnight, it would have a long crank on a cold engine. But after starting and repeatedly shutting down and restarting numerous times throughout the day, it would run fine. Then hard to start again the next morning.
There is no fuel filter and you can have a fuel system pressure test done. Which I did have and the fuel pump was supplying enough pressure and the fuel injectors were not leaking down. Apparently there is a check valve in the fuel pump that was not holding the system pressure overnight but slowly leaking down. Had the fuel pump replaced 08/14 and has fired up within a few seconds ever since.
When you get a chance please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread.
So the trick I tried "turning the key to ON and wait then start" does not work? I thought when the fuel pump starts working, the pressure will be built up even if there is a pressure leak. I found this trick when I searched the internet.
Thank you for your reply. Then do you have any idea how to check if the pump is failing?
