Old 26 Nov 2017, 09:02 pm
TDFF TDFF is offline
Default Re: 2007 pt cruiser engine needs to start twice
Originally Posted by ptcruisersteve View Post
First thing I would suggest is to have a battery load test done. Sometimes batteries do not work properly affecting the electronics in the Pt Cruiser.
If you don't have a fuel pressure gauge I would suggest turning the key to the "On" position, wait 10 seconds, turn the key off for 5 seconds, and then back to the "On" position several times to see if it helps build up the fuel pressure. Then try starting it to see if it starts the first time.
Have you checked for engine trouble codes with the OBDII Scan Tool?
I will try to turn the key ON and OFF several times tomorrow morning. Since the Check Engine Light does not illuminate, I haven't thought about checking codes. I may do it tomorrow as well. I will check the battery once I have time. Thank you very much.
