Old 01 Dec 2017, 10:41 am
ptcruisersteve ptcruisersteve is offline
Default Re: No Start - ideas?
Originally Posted by sniggle View Post
Okay Steve,
I got the car about a week ago. The car had a seized shift cable and a broken shifter. The console was removed and in the back of the car when I got it.
I replaced the cable and the shifter but have not put the console on yet so there are a few things unplugged by the shifter. I haven't looked at the console to see what they plug into.
I had some trouble with the new shift cable but that has been addressed.
The car sat for roughly 9 months. The battery wouldn't take a charge so I borrowed one from my other PT. The engine turns over and will occasionally sputter as if it wants to start but that is as far as it goes. I checked to see if the cam gears were turning and they are. I checked to see if the car had fuel and it does.
That is as far as I have gotten with it.
I would suggest you check for OBDII engine trouble codes. Post if you have codes.
If no codes put starter fluid in the throttle body and see if it starts to run unless you actually verified there is 58 +/- 5 PSI.
If fuel is not the issue I would suggest you check to make sure you have a strong spark in all cylinders. Sometimes one half of the coil goes bad so you need to make sure you check all the cylinders.
If you have strong spark I would suggest you do a engine compression check on all four cylinders.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
