Old 01 Dec 2017, 05:24 pm
ptcruisersteve ptcruisersteve is online now
Default Re: No Start - ideas?
Originally Posted by sniggle View Post
Thanks Steve,
I have tried the following
Codes that come up are P0113, P0522, P0622
I tried a shot of starter fluid but that didn't seem make it try to start any more than before.
That's where I am at right now. Hopefully I'll have time to mess with it some more later.
Oh yea, the starter seems to turn the engine fairly slow. Battery is good and I have even hooked up jumper cables to give it some more juice but still turns over slow
I would suggest checking the battery voltage first when you are cranking. If the battery voltage is below 10.5 volts it will not run properly.
P0113 - IAT Sensor Circuit High Input Conditions:
Possible Causes:
1. IAT Sensor signal circuit shorted to VREF 5 volts
2. IAT Sensor signal circuit is open, or the ground circuit is open
3. IAT Sensor is damaged or it has failed
4. PCM has failed
P0113 can also be caused by a vacuum leak. Check all vacuum hoses. Check to make sure your PCV valve hose is not cracked or leaking and your PCV valve is working properly. They might have pulled a vacuum hose cracking it when it was being checked for smog.
P0522 - Engine Oil Pressure Sensor voltage low:
Possible Causes:
1. 5 volt supply circuit is open or is shorted to ground
2. Oil pressure Sensor signal circuit is shorted to ground or to sensor ground
3. Oil pressure Sensor is damaged or has failed
4. PCM has failed
Your Camshaft or Crankshaft sensor (5 volt line) might be shorting to ground. I would suggest you remove the wire going to the camshaft sensor and try starting the engine without the wire connected.
P0622 - Generator Field Not Switching
Possible causes:
1. Battery charge
2. Faulty Generator
3. Generator harness is open or shorted
4. Generator circuit poor electrical connection
5. Faulty ECM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
