Old 05 Dec 2017, 09:54 pm
rsrocket1's Avatar
rsrocket1 rsrocket1 is offline
Default Re: Automatic Transmission Fluid Pan Replacement
Hi Jeff,
The torque spec for the transmission pan bolts is 165 INCH POUNDS which is 13.75 foot-pounds. That's barely hand tight. The number of bolts plus the give from the gasket is enough to hold the pan.
20 month update. Even though I may have damaged one of the bolts, every time I look under the car at the transmission pan I check and there is zero evidence of any leaking.
That hand pump is great for draining and filling the ATF but replacing the pan with one that has a drain plug is also a good idea. You still have to remove the pan to check the magnet for particles and replace the filter.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
