Old 05 Dec 2017, 10:13 pm
aelfwyne aelfwyne is offline
Default Re: 2003 GT - "PT Salvage"
Originally Posted by myckee View Post
Syked does make a good product, however since he is a one man operation and his ECU business isn't his day job, you could be waiting an extended amount of time before you receive your item. Maybe he has help now and that has changed?
If it was me, for a stage 1, I would send it to Cindy at FWD Performance. They are also in Texas and charge, at last contact, $125 if you supply your own core. While Syked's is supposed to be tweaked a bit more than the one originally offered by Mopar, and which FWD sells, it is doubtful that you would be able to tell the difference. I have both in a manual GT and I can't just beating on the car on the street. I can't speak about the automatic. Cindy's number at FWD is: 281-642-3878
FWD Can't do Stage 2. That is a custom deal only since Mopar never officially released a S2 for the PT. So if S2 is your goal, Syked is the only player.
As far as core goes, sell the GT core and buy a NA core for less than half the price. You may experience a longer life out of the NA core too. After so many years and miles, the GT cores have been subjected to a lot more heat over their lifetime and many of them are failing more frequently. The 02 circuits seem to fail the most often. Any 05 PT or Neon core will work perfectly.
For the 2003 year only, along with the Stage 1 PCM, Mopar also included the injectors used in all 04+ Turbo PTs. They didn't need to supply them for the other years since those were already the factory installed injectors. There has been a lot of debate on this forum as to whether they are actually needed or not. For me, since Chrysler said they were required, then that is good enough for me. It's up to you which path you follow. If you go with Stage 2, then upgraded TIP and MAP sensors, as well as even bigger injectors were supplied by Mopar.
1) May consider FWD Performance. For some reason I got the impression they weren't doing them any more. I was considering visiting Modern Performance (it's not far from me), but it looks like they only have DiabloSports these days.
2) Actually on second look it wasn't a GT core I bought anyway, it was an automatic NA (4 port) core. I knew that at the moment but forgot! Woops. So that's good there.
3) Have been looking at a couple of sources of Stage 1 injectors.
Honestly I will probably just do stage 1. Trying to avoid the crazy cost I hit doing my Abarth with big turbo, plasma coils, etc etc, bought parts multiple times because never happy with what I got, etc. I got the cruiser cheap and don't want to spend too much on it.
Car:
#1: 2015 Fiat 500 Abarth in Rosso RED (MAD FIAT)
#2: 2003 PT Cruiser GT in Boring Beige
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
