Old 06 Dec 2017, 10:09 am
jm4n69 jm4n69 is offline
Default Things I Do When I Get Bored...
I have a mirror-mounted Z-Edge dash cam with backup camera. I love it, it's caught more than a few interesting moments.
Problem is, I wired it to power up with the ACC - which is ideal *most* of the time. However, sometimes I just want to turn it off (say, I'm sitting in the car w/radio or heat on, talking on the phone or whatever). Also it occasionally needs to be power-cycled because it fails to initialize the rear camera or, more often, the rear cam is stuck on a frozen still image. Pulling the USB cable means re-adjusting the mirror etc...
Then there are times where I may wish to have it recording while I'm NOT in the car. From both cameras (which requires USB power).
So... I decided to wire up an ON/OFF/ON toggle. Couldn't find one in the form of a rocker-style switch with separately-wired LED (since I'm technically using it "backwards" - center feeds the load, the two "ON" sides are fed by ACC and B+)...
Anyway I made a video out of the still pictures I took along the way, figured this is the place to post it. Worth noting the background music is my own creation, no copyright issues there.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
